IODEBUG enabled then "unable to retrieve disaseembly data from backend"
danielchai
Senior Contributor I
I enabled
#define BSPCFG_ENABLE_IODEBUG1
and then change
#if BSPCFG_ENABLE_IODEBUG
        #define BSP_DEFAULT_IO_CHANNEL                        "iodebug:"
        #define BSP_DEFAULT_IO_CHANNEL_DEFINED
After I compiling the code and run it, it did print "Hello word" from the IDE console. But it stops at "unable to retrieve disaseembly data from backend"
I don't know if I need set something else?
Thank you.
-Daniel
