How to open the webpage?
winmaxi
Hi, I'm currently reading the code of LAB 4.
How does the code link to the webpage it opens?
In the code there is <server = httpd_server_init((HTTPD_ROOT_DIR_STRUCT*)root_dir, "\\mqx.html");>   I can't locate mqx.html.
Also, could you please tell me how does it go to the root directory of the webpage without spelling out the webpage's address?
Thank you.
M_ttferrari
HI,
Are you installed the tfs?
You need convert your web pages to tfs with mktfs.exe (it is located in somewhere at mqx folder, I don't remember now). This application converts your web pages into a c file (tfs_data.c) then you need to declare a HTTP_ROOT_DIR_STRUCT
const HTTP_ROOT_DIR_STRUCT root_dir[] = {
 { "", "tfs:"},
 { 0, 0}
then before to install your server, install the tfs where the server will find your web pages (and images if you web page has ones).
io_tfs_anstall("tfs", tfs_data);
Please, take a sight to MQX RTCS user guide you will find some examples about how initialize a web server.
Matt
winmaxi
Now I know where the mqx.html locate. But I still don't know how the program indicate where the folder is without spelling out the directory.
Could anyone answer my question?
Thank you
M_ttferrari
HI,
 { "", "tfs:"},
 { 0, 0}
Matt
winmaxi
Thank you very much.
I have question about using mktfs.exe.
When I double click it directly, it will close in about 2 seconds.
When I run it using windows command prompt, what the format is like?
In using MQXlibraries document,
it asks us to input like the following:
mktfs.exe <Folder to be converted> <Output source file name>
for example:
C:\mktfs.exe web_pages tfs_data_file.c
I put mktfs.exe C:.../webpages(the directory of the webpage folder) tfs_data_file.c
it asks me to input [-s <separate file>] <input_directory>
I don't know what it means, so I input as the folliowing:
mktfs.exe C:.../webpages(the directory of the webpage folder) C:..../tfs_data_file.c(where I want to save the translated C document)
it shows the same message.
What exactly the format should be like? Could anyone help me?
