How to identify a mobile browser with RTCS httpd ?
pbanta
I want to serve up a set of pages designed for a mobile screen size if a browser from a mobile client requests data from my MQX http server.  Does the server have any support for doing this?  I can't find much detail in the RTCS User's Guide.
Thanks.
Luis_Garabo
Hi pbanta,
This is not a feature included in MQX. I would rather think that is a web application feature. For instance, you could have javascript detecting if this is a mobile device and then redirect the user to a different link inside your URLs. For instance I found this:
Mobile detection using Javascript - Stack Overflow
I hope this helps.
Garabo
pbanta
Hi Garabo,
Thanks for the reply.  I can see how that would work.  Thanks so much.
Paul
