How To keep personal code with Processor Expert
2,507 次查看
holyhope
Hi to All,
I need to keep my personal code in file:
uartCom1.c
that is auto generate by Processor Expert.
Because there is a BUG I need to NOT autoinitialize my UART code and initialize it in another place.
But I need to keep the variable
uart_state_t uartCom1_State;
and other things that I write in uartCom1.c... but evry time I generate code with processor expert it delete all my uart_state_t uartCom1_State; so it is very boring ALL time rewrite it...
How I can keep my personal code inside Processor-Expert's managed .c files?
2,372 次查看
Jorge_Gonzalez
Hello Massimiliano:
The next tutorial by colleague Erich Styger might answer your question:
Disable my Code Generation | MCU on Eclipse
You need to disable code generation for UART so that your changes are preserved.
Regards!,
Jorge Gonzalez
2,372 次查看
holyhope
Hi to all,
Many thanks.
I'm using MQX on KDS, your answer explain me how to retain my code. Many thanks
Massimiliano
2,373 次查看
Jorge_Gonzalez
Hello Massimiliano:
Regards!,
Jorge Gonzalez
2,372 次查看
soledad
Hello Massimiliano,
Are you using MQX? If you are using MQX please check the MQX_CW10_Getting_Started document (page 42) that you can find at the path: C:\Freescale\Freescale_MQX_4_1\doc\tools
Sol
