HTTP Client in C through MQX
4,816 次查看
renak
Hi All,
   I want to call a Restful JSON webservice using C through MQX.
Is there any HTTP client library ported in MQX which can be used for this?
标记 (4)
5 回复数
3,524 次查看
soledad
Hi Ren,
Sorry but there is not support for JSON request in RTCS. :smileysad:
Sol
3,524 次查看
renak
Ok...thank you for the information.
But, in case if it is NOT json, is it possible?
I mean, how to call a simple web service using C through MQX?
3,521 次查看
soledad
Please check the attachment and let me know if this helps :smileywink:
Sol
3,521 次查看
renak
Thank you for your help, but unfortunately the attachment din't help.
Let me explain my need in simple sentences.
We need to call a url (webservice) from TWRK60F120M.
We are using CodeWarrior as IDE.
Could you please help me in this regard?
Can you please provide some links which can guide us to get a solution?
3,521 次查看
danielchai
Senior Contributor I
