GT202 WiFi qcom_api gcc_arm porting on frdmk22f120m MQX
1,894 次查看
avijitsur
Has anybody ported qcom_api for GT202 WiFi module on frdmk22f120m mqx  platform in arm gcc ?
The same is available for IAR MQX but not for arm gcc.
1,236 次查看
soledad
Please check the below doc and let me know if this helps!!!
MQX Wi-Fi SoftAP Demo
Sol
1,236 次查看
avijitsur
Thanks.
But that project is built with IAR not arm gcc. We tried to build qcom_api library with arm gcc tool. It is not very clear what are the source driver files to be included in build process to make qcom_api.a library.
1,236 次查看
sur_avijit
qcom_api library for GT202 WiFi module on frdmk22f120m MQX has been ported in ARM gcc
