FXOS8700CQ file pointer "MQX_FILE_PTR". unknown data type
3,850件の閲覧回数
stevenbell11
FXOS8700CQ: Datasheet page 26 example code lists a file pointer "MQX_FILE_PTR". When I compile the code I get an error saying it is an unknown data type, do you know how to fix this?
3,366件の閲覧回数
Sudhar_27102001
can u give me the driver code for fxo8700cq. Facing sensor initialization failed error.in FRDM-K32L2B3 BOARD. pls help me on this.
3,692件の閲覧回数
danielchen
Hi  Steven
I would suggest you refer to the below document, it includes an example code written for Frdm-k64F board, using polled i2c MQX driver for communication  with FXOS8700CQ chip.
Accelerometer and magnetometer FXOS8700CQ example code for MQX4.1.1
I hope it helps
Note: If this post answers your question, please click the Correct Answer button or helpful. Thank you!
