FRDM-KV31F
FRDM-KV31F
2,496件の閲覧回数
chenqian
How does FRDM-KV31F start learning?
And where to find examples?
And there is an update after downloading the software. Why did it not work well after fifty percent?
It shows that a website is not accessible.
4 返答(返信)
2,248件の閲覧回数
chenqian
Hi Daniel:
First of all, thank you very much.
Also, I would like to ask that this development board supports the compilation and download of MATLAB/SIMULINK. However, after I set up his PDF document, there was a problem when compiling and downloading his own model.
I don't know whether it's his own model problem or my setup problem.How should this be solved?(And,I use  MATLAB2014a/b)
Gududexue
2,248件の閲覧回数
danielchen
Hi gududexue
Please download SDK for Frdm-kv31f from  https://mcuxpresso.nxp.com/en/select
You can download documents for learning.
If you can not download it successfully, you can generate a shared link, and copy and paste that link in the browser to try it again.
The examples is under the folder
SDK_2.4.1_FRDM-KV31F\boards\frdmkv31f
2,248件の閲覧回数
chenqian
Hi! Daniel Chen
      You said that I have found it, and according to the video on (
)  this website, I have made a preliminary study of SDK software, but I have encountered several problems.
Firstly, the following errors are displayed in the following operation,
This error will be displayed in the end.
(Unable to read repository at http://gnuarmeclipse.sourceforge.net/updates/content.xml.
Connection reset)
Then the following errors occur when the development board is subinstalled in the real program.
2,248件の閲覧回数
danielchen
Hi Gududexue:
From your picture, you are using KDS ide.
I would suggest you select USB Multilink interface and try it again.
I also suggest you use MCUXpresso IDE if possible, since MCUXpresso IDE replaced KDS now.
