FRDM K64F giving \n\nOK\n\n as output instead of \r\nOK\r\n
1,780 次查看
oliviachristyva
I am interfacing FRDM K64F with Zigbee ETRX357. I am getting the output and my UART code is working but instead of the output \r\nOK\r\n for an AT\r transmitted i am getting \n\nOK\n\n. I cannot understand what is the reason.
Please help me if you have got any clues..
Olivia
1,554 次查看
oliviachristyva
Hi guys,
Just add these lines after you open your port.Because the IO_SERIAL_NON_BLOCKING which you enable at the time of opening a port is not working that was the issue.
setflag = IO_SERIAL_NON_BLOCKING;
ioctl(GSM_Port, IO_IOCTL_SERIAL_SET_FLAGS,&setflag);
Hope it helps someone.
Thanks and Regards,
Olivia
4 回复数
1,555 次查看
oliviachristyva
Hi guys,
Thanks and Regards,
Olivia
1,554 次查看
danielchen
Thank you for your update, Olivia
1,554 次查看
danielchen
Hi Olivia:
I think this is a terminal parse issue rather than an uart issue. I would suggest you detect and compare the signal with your scope first.
1,554 次查看
oliviachristyva
hi Daniel,
I am not getting the output through the terminal. I am just debugging and watching the variable in KDS. Does this has something to do with the translation flags in MQX.
Olivia
