Error when configuring module in EB tresos 23.0.0
3,641 次查看
edisonwang2016
Module "CanIf_TS_T40D2M10I3R0" (defined in plugin "CanIf_TS_T40D2M10I3R0") defines the schema file "config/CanIf.xdm" which cannot be found (if the file is signed or crypted, it must be referenced in META-INF\CRYPTOMANIFEST.MF).
3,542 次查看
danielchen
What chip you are using?  If you are using S32K, I would suggest you post your question in S32K forum.
https://community.nxp.com/community/s32/s32k
Thank you for your understanding.
3,002 次查看
wl_ch
I have met the same problem, the chip is MPC5748C, it has cause series delay of project timing,would you like to help me ?
