Does the CGI script in a HTTPServer run during an interrupt?
t_k
I'm using MQX 4.1.2 on a MCF54417.  while trying to set up a HTTP Server, the device keeps resetting with an Interrupt Overflow.  Does the CGI script run during an interrupt?
Martin_
CGI script is just a task (at priority 7). Thus, it runs only if no interrupt service routine or higher/equal priority task runs.
-Martin
