Does NFC and DMA operation possible?
naftalir
Hi all,
is the MQX NFC Driver supports the DMA operation? or do i need to change the MQX NFC driver completely to work with the DMA?
thanks!! :smileyhappy:
Martin_
Hi naftalir,
MQX NFC driver doesn't use NFC's integrated DMA engine. You will need to change the driver if you wish to use the integrated DMA engine.
