CodeWarrior Not Found Even If it is Installed
2,241 次查看
RohanShah
I have Installed CodeWarrior for MCU v10.1 successfully & then I started installing MQX 3.6.2, its installer did searched for CodeWarrior as usual, but it failed to find it. (Please ref. screenshot attached).
Can anyone guide how I can link MQX with CodeWarrior workbench?
Thanks in advance.
1,700 次查看
petr_uhlir
its because MQX 3.6.2 does not support TAD plugin for CodeWarrior for MCU v10.1 yet. It will be enabled  in next MQX release.
1,701 次查看
petr_uhlir
1,699 次查看
TomR
I am having the same problem.
The only version of CodeWarrior 10 to download is version 10.1. Does this mean I can't do MQX development with CW10.1 and MQX 3.6.2?
