Can we reduce timeout when transmit UDP packet
1,212件の閲覧回数
isaotakashima
We want to reduce timeout from 180 seconds to 10 seconds when transmit UDP packet.
I understood that they can reduce to 10 seconds by modify RTCSCFG_ARPTIME_EXPIRE_INCOMPLETE as below.
    #define RTCSCFG_ARPTIME_EXPIRE_INCOMPLETE    10000L   /* Change to 10 sec from 180000L  3 min */
Does this change cause any problem?
Could you please let us know minimum timeout value.
Please reply as soon as possible.
Takashima
3 返答(返信)
972件の閲覧回数
DavidS
Hi Takashima,
It is OK to change that #define to shorter time.
David
972件の閲覧回数
isaotakashima
Dear David,
Thank you for your quick reply.
I understood that I can change that #define to shorter time.
Do you have specific minimum short time?
Takashima
972件の閲覧回数
DavidS
Hi Takashima,
It is application dependent so set it to what works for your application.
David
