CMSIS DSP Library for Freescale compiler
2,839 次查看
shihab_thadathi
I want to use CMSIS DSP library functions for my MQX 4.0 project that works in TWRK70f120M using code_warrior IDE. I am able to use this functions for bareboard project using gcc compiler, but it shows Unknown compiler Error. Can i use cmsis dsp lib with freescale compiler?. Is there any document or guide describing  CMSIS lib porting for freescale compiler?.
Shihab
标记 (4)
6 回复数
2,338 次查看
ZhangJennie
hello Shihab,
please refer threads:
https://community.freescale.com/message/350214#350214
https://community.freescale.com/thread/324740
this answer is for you. if it helps, please click on "Correct Answer" button. thanks!
ZhangJun
2,338 次查看
shihab_thadathi
Hi ZhangJennie ,
All of these links describe the use of CMSIS lib using gcc compiler. Is this possible with freescale compiler?
Shihab
2,338 次查看
ZhangJennie
Hi Shihab,
I have a CMSIS samples ever made under FSL compiler CW10.2. but it's around 30M. please send me your email address so that i can send it to you via transweb.
thanks!
ZhangJun
2,338 次查看
shihab_thadathi
Thanks ZhangJennie,
I have send you a message containing my email address.
2,338 次查看
ZhangJennie
Hi Shihab,
i just sent. the description of it is in SR 1-2924409127
ZhangJun
2,338 次查看
shihab_thadathi
Thanks a lot ZhangJennie,
I will check this
Shihab
