CDC not working
CDC not working
1,927 次查看
orsadeh
i am trying to open a connection from my TWR-K70 as a usb host to a Telit he910.
i used the cdc example and all the attach works but when i try to send data on the port to the Telit the Telit doesnt answer....
when i connect the Telit  to my computer and open hyperterminal i get a response from the Telit....
i dont know whats not working...
i'v attached my code to the post....
tnx...
Original Attachment has been moved to: cdc_serial.rar
1,504 次查看
carlnormansuret
Contributor V
Did you get this working, I am about to start this project. I tried this about 3 years ago and gave up as I could just use the serial port. Any chance you could share your results?
1,504 次查看
CarlFST60L
Senior Contributor II
How did you go with this? I am looking into starting a project requiring this exact solution. Can you share your results or give some points as to what steps are required to get it working?
1,504 次查看
soledad
Hi Sadeh,
Have you ensured that Telit he910 is able to operate as standard CDC device without forcefully requiring a custom driver?
I have tested MQX’s CDC Host application with TWR-K70 and a Freescale USB2SER part (DCD device), and communication is properly established. I also tested with another Freescale MCU programmed as CDC device (using MQX or USB Stack) and it also worked properly.
Soledad
