Bug in MQX 4.1.1. ftpsrv_size
783 次查看
CorderBollie
Hello. I found a bug in function ftpsrv_size (MQX 4.1.1) around line 443..449
   fp = fopen(full_path,"r");
    _mem_free(full_path);
    if (fp == NULL)
        ftpsrv_send_msg(session, ftpsrvmsg_no_file);
        return(FTPSRV_ERROR);
should be
    if (fp == NULL)
        session->message = (char*) ftpsrvmsg_no_file;
Without that change the ftp server sends a wrong response to the client if the file does not exist.
681 次查看
karelm_
thank you for your report. I will fix this bug on our development branch so it is propagated into next MQX release.
Karel
