BSPCloningWizard Java error
1,540 次查看
carlnormansuret
Hi All,
I have spent three hours trying to fix this issue and cannot work it out. I have windows 7 64bit and get this error when i try to run the cloning wizard
Java is enabled, I have completely uninstalled it twice, same with MQX4.2, still no luck.
I have another machine that it works fine on, and it use to work fine on this machine until I rebuilt it a couple weeks ago.
I have recently installed KDS, but normally use CW10.7. Everything else on this computer works fine.
I did find another post with a similar issue and he said he found a 32bit version java and that fixed it, but i think the ini file tells it to use x86 so it might be an old post.
1,394 次查看
carlnormansuret
Im not sure I understand how to tell Java what to do, it installs itself into program files, it has the x86_x64 listed..
You must be partly right though, my "other" computer is installed under x86 program files and works fine just like your java settings above. Maybe its a path issue or something?
Is this really a me problem, isn't this something for the developers to sort out? I have lodged a support ticked hopefully they can get someone on to it that is responsible for this product and they can offer a solution.
1,394 次查看
danielchen
Hi Carl:
I think this issue maybe resulted from the mismatch of the version of Java.  I am using Windows 7 64bit OS, also installed with KDS3.2  and CW10.6.4. Not found issue with BSPCloning Wizard. Please refer to my Java settings.
