Are there any risks to using stdlib qsort() on an MQX 4.2 Kinetis K60 system?
1,200 次查看
dmitriyc
I would like to sort an array of structs and the qsort() in stdlib.h looks like a good solution as opposed to rolling my own sort function. I don't need that much speed, so the generic standard function should be fine for this. Are there any dangers in doing this? For example, is the qsort() implemented as a recursive function, creating the need to be very careful with the task's stack size?
Has anyone else had experience using qsort in an MQX system?
标记 (2)
981 次查看
Carlos_Musich
Hi dmitriyc,
As you say... You must be very careful with the task stack. I have not tried qsort() or other recursive functions. But in my experience I saw that printf() using floats will overflow a task's stack very fast.
Carlos
982 次查看
Carlos_Musich
Hi dmitriyc,
Carlos
