After wake up from LLS, MQX function does not work.
885件の閲覧回数
danielchai
Senior Contributor I
After the system wakes up from LLS using  LLWU PTD0,  it run the instruction after asm("WFI").
But after asm("WFI"), I use lwgpio_init function to initialize the gpio, but it does not work.
I have to reset the register through set the registers directly then I can use lwgpio_init function.
Any suggestion about this?
Thank you.
-Daniel
タグ(4)
0 返答(返信)
