After compile the MQX, it work sometime.
1,668 次查看
danielchai
Senior Contributor I
Hi all,
I use CW10.4 and MQX3.8. After I recompile the MQX, I try to build my project. But sometime it give me error
mingw-32-make:***[intflash_d.afx]Error1
No library file found matching 'libbsp_twrk60512_d.a{.dylib|.a}' or 'bsp_twrk60n512_d.a'
sometimes there is no this error.
Any ideas about this?
Thank you.
标记 (3)
1,539 次查看
apanecatl
Senior Contributor II
You need to re-compile the libraries before compiling the project, try doing that and let us know how it went :smileygrin:
1,540 次查看
apanecatl
