ADC interrupt problem
4,231 次查看
vitormayer
I am using MQX lite 1.1.1 and when I try to use ADC_LDD with interrupt i got the message:
Description Resource Path Location Type
undefined reference to `AD1_OnMeasurementComplete' AD1.c /my_project/Generated_Code line 399 C/C++ Problem
If I try use another timer interrupt, and I got the same message.
I  had all #include declared.
Any one could help me?
4,132 次查看
vitormayer
I am using KDS3.0.0 with a custom board with processor Mk64f.
Thank you for your attention, But I find the problem.
It was when I generate the PEx code, the new part of code was created inside the another function, and it was generating the undefine reference.
thanks one more time.
4,132 次查看
vitormayer
4,132 次查看
danielchen
Hi Vitor:
Could you please provide more information for us to reproduce your issue? Which IDE you are using. Codewarrior 10.7 or KDS 3.2?   TWR-K64 board or other?
