A bootloader via MQX RTCS
2,278 次查看
小勇邹
Is there any solution for MQX RTCS to update the FW through Ethernet/Internet?The device is k64.
1,843 次查看
Martin_
FNET TCP/IP Stack is a bootloader ready for K64
or
mqx\examples\bootloader\ (this would need port from ColdFire to Kinetis, should not be that difficult, but is not out of box ready for K64)
or
c:\Freescale\Freescale_MQX_4_1\shell\source\rtcs\sh_exec.c / c:\Freescale\Freescale_MQX_4_1\shell\source\rtcs\sh_load.c (however, these files are considered as legacy, and they are not present in next MQX release versions).
1,844 次查看
Martin_
or
or
