MQX3.8+CW10.6
MQX3.8+CW10.6
fjiewjg
Hello, I'm planning to conduct project development using the MQX operating system. The platform I'm using is CW10.6. I have downloaded the MQX 3.8 software package. However, I'm not sure how to create an engineering project and burn the program through MQX. I would appreciate it if you could provide some relevant routines and materials. Thank you.
danielchen
Hi @fjiewjg :
If you have the MQX software package,  you can find the document inside the package such as getting started guider and reference manual, etc.. there is a folder named document.
fjiewjg
Yes, I have seen this document. However, following the operation steps cannot be achieved. May I ask if the software package of MQX3.8 is compatible with CW10.6? Also, are there any examples or routines available for reference for learning?
danielchen
please check the release note,   the supported toolchain is described.
fjiewjg
The simulator I'm using is PE_Multilink. How should I make the modification?
danielchen
HI
This error maybe maybe related with Codewarrior version.
I would suggest you ask this question from Codewarrior community.
CodeWarrior - NXP Community
fjiewjg
Hello, I have a question. In the MQX3.8 software package, the simulation tool used for the project in mqx/examples is USB. However, I am using Multilink. Could you please tell me how to change it?
danielchen
HI @fjiewjg
For Codewarrior IDE issues, I would suggest you post your question on codewarrior community.
CodeWarrior Development Tools - NXP Community
fjiewjg
When operating with the "FSL_MQX_in_CW_10_x" file and importing the "hello" project, this error occurs. Could you please tell me what's the reason?
fjiewjg
May I ask if there is an installation package for CW10.2? I need the 10.2 version. I haven't found it yet.
