Video Training Series: Essentials of MQX RTOS Application Development
New to MQX RTOS?  Get up to speed quickly with the Essentials of MQX RTOS Application Development online video series.
评论
macl‌: Is this training still available somewhere (the links are dead here) or was it replaced with another?
Thanks!
Hi Rudy,
The home for these videos has moved around a bit. The safest way to get there is to start with www.nxp.com/mqxv5 and select the 'Training & Support' tab at the top right. You should see the 'Essentials of MQX RTOS Application Development' link which will take you to a repository for online training. Type 'Essentials of MQX RTOS Application Development' into the search bar ( a shorter version of the title should work as well) and then select the MQX course when it comes up in the search. Somewhere along the way it may ask you to sign in to the NXP website with your login ID.
Let me know if you have any issues.
Doug Bruce
Thanks!
无评分
版本历史
最后更新:
‎02-27-2015 09:12 AM
更新人:
