vTaskdelay(), vTaskdelayuntil() call doesn't work on MPC5748G.
2,163 次查看
nirmal_kumar
I created a project on Z0 core. -> Added freertos component via PE -> Generated the code.
On creating the task, it is successful.
But when i used vTaskdelay() inside the task, the application crashes. Removing the call woks fine.
I had to use vTaskdelay(), vTaskdelayUntil() in my application.
I couldn't able to solve this. Kindly help.
Attached sample code.
1,939 次查看
xierxiaofeng
Hi Nirmalkumar,
    Have you resolved this problem? I encountered the same problem.
Thannks!
