store data or array in memory MPC5748G DEVKIT
1,430件の閲覧回数
turkmani_11
hello, i have a simple question, im new to the NXP microcontrollers , right now i have a MPC 5748G DEV KIT , i would like to store data in its memory, an array for example. how can i do it in S32 design studio code?
タグ(5)
1,396件の閲覧回数
lukaszadrapa
if you have some data in srecord or hex format, you can follow:
https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/HOWTO-download-separate-elf-srec-hex-f...
If you want to put some data to your project, simply define it as constant data like:
const unsigned int test_data[] = {0,1,2,3};
Then it will be added to default rodata section. Or you can modify the linker file and create own section.
Lukas
