snooping mode
snooping mode
2,393件の閲覧回数
marcellobellini
in MPC5777C snooping mode do not work with EBI set to demultiplexed 16-bit bus?  I tried it with 32 bit bus multiplexed and it works.
4 返答(返信)
2,275件の閲覧回数
marcellobellini
when I use the memory coherence unit to synchronize the two cores, usually called snooping mode, actually the mechanism does not always work properly.  This operation is performed in external memory on 16-bit EBI
2,275件の閲覧回数
davidtosenovjan
I am sorry, I have completely forgotten on this thread.
Could you give me as much details as possible? Source codes (EBI settings, cache and coherency unit), maybe schematic of connection. When the problem happen and how it manifest? Thanks
2,275件の閲覧回数
marcellobellini
I will prepare some documentation and C example.
the card is the same where improperly does the burst on external memory, but by mounting the MPC5674, the burst goes.
so i think that isn't a HW problem
the card works properly if you do not use the burst, The cache works
The card is already in production, but we do not use  burst and second core
2,275件の閲覧回数
davidtosenovjan
I am not sure if I understand the question. The term "snooping" ca have something to do JTAG or coherency unit. But how it is related to EBI module? Could you please clarify your question? Thanks
