shut down BIST
shut down BIST
2,802 次查看
abdelrhman
the BIST preparation gates off the clocks for the MCU peripherals
so, how to access the shut down BIST results ??
标记 (1)
2,789 次查看
abdelrhman
Okay I get it
Thank you very much
2,790 次查看
abdelrhman
Okay I get it
Thank you very much
2,794 次查看
petervlna
You will read the results after BIST finish and it trigger reset.
Right after reset you can read Shutdown and also startup BIST results in STCU status registers.
Peter
