random seed generator
2,469件の閲覧回数
bjrajendra
Senior Contributor I
Hello all,
I'm using MPC5602P on CW2.9 platform. I want to generate random seed in my application. Mainly I want to use CORE registers for generating this. How to use CORE registers? Kindly help me in generating this.
Thanks in advance,
Raju
3 返答(返信)
2,239件の閲覧回数
petervlna
For the work with core registers refer to the core reference manual chapter2:
https://www.nxp.com/docs/en/reference-manual/e200z0RM.pdf?fsrch=1&sr=1&pageNum=1
For random number generation you can use for example PLL lock time measurement.
Peter
2,239件の閲覧回数
bjrajendra
Hi Peter,
As you said, for random number generation one can use for PLL lock time measurement. My question is there is no register in MPC5602P which gives lock time data.Can you kindly suggest which register exactly I need to check to get the Lock time as random number variable.
BJ Rajendranath.
2,239件の閲覧回数
bjrajendra
Hi Peter,
Can I know exactly which register you are talking about for random number generation.
Raju
