Hello
I am working with Ethernet in MPC5748G LCEVB. I am using the default code in the S32DS v 1.2. While running the code, the board will receive the first two UDP packets. After that it does not receiving any packets. I changed the number of receiver descriptor from 2 to 5. But I can't found out any difference in the program. Is there any one know why it happens? What will be the reason for it?
Thanking you in advance.
Rahul Ramakrishnan
