mpc5748g enet d-cache
已解决
跳至解决方案
3,956 次查看
tomyqg
Hi, everyone!
How to configure the D-cache for memory and put the enet Rx Description and Tx Description in the un-cachable memory space on MPC5748G?
标签 (1)
标记 (1)
1 解答
3,462 次查看
tomyqg
Thank you very much, SMPU is the point!
在原帖中查看解决方案
2 回复数
3,462 次查看
lukaszadrapa
data cache can be enabled in this way:
__dcache_cfg:
        e_li r5, 0x2
        mtspr 1010,r5
        e_li r7, 0x4
        e_li r8, 0x2
        e_lis    r11,0xFFFF
        e_or2i    r11,0xFFFB
__dcache_inv:
        mfspr r9, 1010
        and.  r10, r7, r9
        e_beq   __dcache_no_abort
        and.  r10, r11, r9
        mtspr 1010, r10
        e_b __icache_cfg
__dcache_no_abort:
        and.  r10, r8, r9
        e_bne __dcache_inv
        mfspr r5, 1010
        e_ori   r5, r5, 0x0001
        se_isync
        msync
        mtspr 1010, r5
If you want to configure certain address space as cache inhibited, use SMPU module. Simple example for SMPU configuration can be found here:
Example MPC5748G SMPU initialization
"Cache Inhibit" bit CI can be found in Word 3 of the descriptor (register SMPUx_RGDn_WRD3).
Lukas
3,463 次查看
tomyqg
