linflexd master transmit
1,886 次查看
gangzhou
I use dev kit and Peak usb-can-pro adapter.I use the example "linflexd_lin" from S32DS,dev kit as lin master.But,the adapter receives nothing.when the programm run.What is wrong?b55689@
1,810 次查看
PetrS
please specify the MCU you use.
BR, Petr
1,810 次查看
gangzhou
I use mpc5748g.
