inputcatch IPWM on EMIOS0 MPC5748G
3,526件の閲覧回数
Ben_500
I'm using DEVKIT-MPC5748G and I want to get 4 PWM signals from CH 10, 11, 12, 13 EMIOS0
thanks to sample code I can get 1 PWM signal from EMIOS from CH 13.
And for other PWM input,
EMIOS_0_CH10_CH11_IRQhandler , MIOS_0_CH12_CH13_IRQhandler is not entered.
and eMIOS_UC_0.UC[t_channel].S.R is not updated.
for now, I copied and pasted for other IPWM below code.
(Of course, I changed each index and channel number)
t_Index = 4;
t_Channel = 13;
eMIOS_UC_0.UC[t_Channel].C.B.EDPOL = vEcaleMIOS_Info[t_Index].Edpol_u8;
eMIOS_UC_0.UC[t_Channel].C.B.EDSEL = vEcaleMIOS_Info[t_Index].Edsel_u8;
eMIOS_UC_0.UC[t_Channel].C.B.FEN = 0;
eMIOS_UC_0.UC[t_Channel].A.R = 0x0000FFFF;
eMIOS_UC_0.UC[t_Channel].C.B.IF = 1;
eMIOS_UC_0.UC[t_Channel].C.B.BSL = 0;
eMIOS_UC_0.UC[t_Channel].C.B.MODE = vEcaleMIOS_Info[t_Index].Mode_u8;
eMIOS_UC_0.UC[t_Channel].C.B.UCPRE = 0;
eMIOS_UC_0.UC[t_Channel].C.B.UCPREN = 1;
INTC.PSR[MCALEMIOS_0_CH12_CH13_PSR].R = PRC_SEL_CPU0 | PRC_PRI(7);
eMIOS_UC_0.UC[t_Channel].C.B.FEN = 1;
Can you help this??
タグ(3)
3,349件の閲覧回数
petervlna
I want 4 PWM input capture by eMIOS.
for input capture I set the channel No 10, 11, 12, 13 in module 0 from Pin port PF12, PA0, PG7, PG9
Ok, looking at reference manual on channels 10,11,12,13 can be set input capture on eMIOS0 and eMIOS1:
but CPU get just 1 PWM input despite of using same code.
i have no idea what code you have used.
But simply set the pins for input in SIUL2:
Looking at IO_MUX table I see following ports available:
that could express your issues as only PA0 is mapped to the eMISO from your pins.
Peter
7 返答(返信)
3,471件の閲覧回数
petervlna
what I want is to get Freq and Duty in BSW from signal box.
Please state clearly your requirements
like : I want 4 PWM signals to be captured by eMIOS, and generated 2 PWM outputs.
on each period I want to rise interrupt / DMA etc....
So I see clearly what you are looking for, then I can guide you/give hints.
Peter
3,418件の閲覧回数
Ben_500
Sorry for unclear requirement.
It seems that CPU cannot get imput signal from Pin Port initialization.
I couldnt clarify which part of code is wrong.(Port initialzation? not active Vector table?)
So Please tell me PWM input capture sequence spcifically.
Still unclear to explain,,, Sorry for the inconvenience
3,350件の閲覧回数
petervlna
Peter
3,299件の閲覧回数
Ben_500
For now, I think Hw pin configuration would be answer.
Thanks a lot!!
タグ(3)
3,503件の閲覧回数
petervlna
This example show how to create shifted PWM channels. Simply add more channels as you like by following the 2 channels configured in example.
Code can be reused on MPC5748G.
https://community.nxp.com/t5/MPC5xxx-Knowledge-Base/Example-MPC5746C-eMIOS-Shifted-PWM-GHS716/ta-p/1...
Peter
3,496件の閲覧回数
Ben_500
First of all, Thanks for your support!!
but is it can be applied on IPWM input catch?
I think current source code is made for the modes of EMIOS are OPWM like below
eMIOS_UC_0.UC[0].C.B.MODE = 0x60; // OWPMB mode
3,482件の閲覧回数
Ben_500
And I also found that each IRQhandler is not active.
So, I want to know why the IRQhandler is not active inspite each port pin received the PWM input.
I have no idea why eMIOS_UC.UC[channel].S.R is not set as 1
%3CLINGO-SUB%20id%3D%22lingo-sub-2038111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EEMIOS0%20MPC5748G%20%E3%81%AE%20inputcatch%20IPWM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2038111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FDEVKIT-MPC5748G%2Fpd-p%2FDEVKIT-MPC5748G%22%20class%3D%22lia-product-mention%22%20data-product%3D%223210-1%22%20target%3D%22_blank%22%3EDEVKIT-MPC5748G%3C%2FA%3E%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81CH%2010%E3%80%8111%E3%80%8112%E3%80%8113%20EMIOS0%20%E3%81%8B%E3%82%89%204%20%E3%81%A4%E3%81%AE%20PWM%20%E4%BF%A1%E5%8F%B7%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%81%8A%E3%81%8B%E3%81%92%E3%81%A7%E3%80%81CH13%E3%81%8B%E3%82%89EMIOS%E3%81%8B%E3%82%891%E3%81%A4%E3%81%AEPWM%E4%BF%A1%E5%8F%B7%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%3E%3CSPAN%3E%E3%81%BE%E3%81%9F%3C%2FSPAN%3E%E3%80%81%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AEPWM%E5%85%A5%E5%8A%9B%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3CBR%20%2F%3E%3CSTRONG%3EEMIOS_0_CH10_CH11_IRQhandler%20%E3%80%81MIOS_0_CH12_CH13_IRQhandler%E3%81%AF%E5%85%A5%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%E3%81%8A%E3%82%88%E3%81%B3%3CSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3E%20eMIOS_UC_0.UC%5Bt_channel%5D%E3%80%82SR%E3%81%AF%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E4%BB%8A%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E7%A7%81%E3%81%AF%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E4%B8%8B%E3%81%AE%E4%BB%96%E3%81%AEIPWM%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E8%B2%BC%E3%82%8A%E4%BB%98%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSTRONG%3E%3CBR%20%2F%3E(%E3%82%82%E3%81%A1%E3%82%8D%E3%82%93%E3%80%81%E5%90%84%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A8%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E7%95%AA%E5%8F%B7%E3%81%AF%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F)%3C%2FP%3E%3CDIV%3E%3CSPAN%3Et_Index%20%3D%204%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Et_Channel%20%3D%2013%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EeMIOS_UC_0.UC%5Bt_Channel%5D.C.B.EDPOL%20%3D%20vEcaleMIOS_Info%5Bt_Index%5D.Edpol_u8%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EeMIOS_UC_0.UC%5Bt_Channel%5D.C.B.EDSEL%20%3D%20vEcaleMIOS_Info%5Bt_Index%5D.Edsel_u8%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EeMIOS_UC_0.UC%5Bt_Channel%5D.C.B.FEN%20%3D%200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EeMIOS_UC_0.UC%5Bt_Channel%5D%E3%80%82A.R%20%3D%200x0000FFFF%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EeMIOS_UC_0.UC%5Bt_Channel%5D.C.B.IF%20%3D%201%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EeMIOS_UC_0.UC%5Bt_Channel%5D.C.B.BSL%20%3D%200%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EeMIOS_UC_0.UC%5Bt_Channel%5D.C.B.MODE%20%3D%20vEcaleMIOS_Info%5Bt_Index%5D.Mode_u8%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EeMIOS_UC_0.UC%5Bt_Channel%5D.C.B.UCPRE%20%3D%200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EeMIOS_UC_0.UC%5Bt_Channel%5D.C.B.UCPREN%20%3D%201%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINTC.PSR%5BMCALEMIOS_0_CH12_CH13_PSR%5D.R%20%3D%20PRC_SEL_CPU0%20%7C%20PRC_PRI(7)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EeMIOS_UC_0.UC%5Bt_Channel%5D.C.B.FEN%20%3D%201%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E3%81%93%E3%82%8C%E3%82%92%E5%8A%A9%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2043968%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AEMIOS0%20MPC5748G%E3%81%AEinputcatch%20IPWM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2043968%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BB%8A%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81Hw%E3%83%94%E3%83%B3%E6%A7%8B%E6%88%90%E3%81%8C%E7%AD%94%E3%81%88%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2043321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AEMIOS0%20MPC5748G%E3%81%AEinputcatch%20IPWM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2043321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%3CSTRONG%3EeMIOS%E3%81%AB%E3%82%88%E3%82%8B4%E3%81%A4%E3%81%AEPWM%E5%85%A5%E5%8A%9B%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E7%94%A8%E3%81%AB%E3%80%81%E3%83%94%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88PF10%E3%80%81PA12%E3%80%81PG7%E3%80%81PG9%E3%81%8B%E3%82%89%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB0%E3%81%AE%E3%83%81%E3%83%A3%E3%83%8D%E3%83%ABNo10%E3%80%8111%E3%80%8112%E3%80%8113%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB10%E3%80%8111%E3%80%8112%E3%80%8113%E3%81%AE%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%A8%E3%80%81eMIOS0%E3%81%8A%E3%82%88%E3%81%B3eMIOS1%E3%81%A7%E5%85%A5%E5%8A%9B%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_0-1739190733633.png%22%20style%3D%22width%3A%20654px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_0-1739190733633.png%22%20style%3D%22width%3A%20654px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F323168iCB27A8BFC94840B9%2Fimage-dimensions%2F654x232%3Fv%3Dv2%22%20width%3D%22654%22%20height%3D%22232%22%20role%3D%22button%22%20title%3D%22petervlna_0-1739190733633.png%22%20alt%3D%22petervlna_0-1739190733633.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_2-1739190759866.png%22%20style%3D%22width%3A%20646px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_2-1739190759866.png%22%20style%3D%22width%3A%20646px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F323170i980C57FBC62DDD44%2Fimage-dimensions%2F646x231%3Fv%3Dv2%22%20width%3D%22646%22%20height%3D%22231%22%20role%3D%22button%22%20title%3D%22petervlna_2-1739190759866.png%22%20alt%3D%22petervlna_2-1739190759866.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81CPU%E3%81%AF%E5%90%8C%E3%81%98%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%811%E3%81%A4%E3%81%AEPWM%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%8B%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E3%81%A9%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%AE%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81SIUL2%20%E3%81%A7%E5%85%A5%E5%8A%9B%E7%94%A8%E3%81%AE%E3%83%94%E3%83%B3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EIO_MUX%E8%A1%A8%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%A8%E6%AC%A1%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%E3%83%94%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88PF12%E3%80%81PA0%E3%80%81PG7%E3%80%81PG9%E3%81%8B%E3%82%89%E3%81%AE%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB0%E3%81%AENo10%E3%80%8111%E3%80%8112%E3%80%8113%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22petervlna_0-1739440214672.png%22%20style%3D%22width%3A%20570px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22petervlna_0-1739440214672.png%22%20style%3D%22width%3A%20570px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F323821i2207A5C90795B6E9%2Fimage-dimensions%2F570x332%3Fv%3Dv2%22%20width%3D%22570%22%20height%3D%22332%22%20role%3D%22button%22%20title%3D%22petervlna_0-1739440214672.png%22%20alt%3D%22petervlna_0-1739440214672.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81PA0%E3%81%AE%E3%81%BF%E3%81%8C%E3%83%94%E3%83%B3%E3%81%8B%E3%82%89eMISO%E3%81%AB%E3%83%9E%E3%83%83%E3%83%97%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%95%8F%E9%A1%8C%E3%82%92%E8%A1%A8%E3%81%99%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2040474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AEMIOS0%20MPC5748G%E3%81%AEinputcatch%20IPWM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2040474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A6%81%E4%BB%B6%E3%81%8C%E4%B8%8D%E6%98%8E%E7%9E%AD%E3%81%A7%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3EeMIOS%E3%81%AB%E3%82%88%E3%82%8B4%E3%81%A4%E3%81%AEPWM%E5%85%A5%E5%8A%9B%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E7%94%A8%E3%81%AB%E3%80%81%E3%83%94%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88PF10%E3%80%81PA12%E3%80%81PG7%E3%80%81PG9%E3%81%8B%E3%82%89%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB0%E3%81%AE%E3%83%81%E3%83%A3%E3%83%8D%E3%83%ABNo10%E3%80%8111%E3%80%8112%E3%80%8113%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81CPU%E3%81%AF%E5%90%8C%E3%81%98%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%811%E3%81%A4%E3%81%AEPWM%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%8B%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3ECPU%E3%81%8C%E3%83%94%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%8B%E3%82%89%E5%85%A5%E5%8A%9B%E4%BF%A1%E5%8F%B7%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%81%A9%E3%81%AE%E9%83%A8%E5%88%86%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82(%E3%83%9D%E3%83%BC%E3%83%88%E5%88%9D%E6%9C%9F%E5%8C%96%3F%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%A7%E3%81%AA%E3%81%84%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3F%3C%2FP%3E%3CP%3E%E3%81%A7%E3%81%AF%E3%80%81PWM%E5%85%A5%E5%8A%9B%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%82%92%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AB%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%A0%E8%AA%AC%E6%98%8E%E3%81%8C%E4%B8%8D%E6%98%8E%E7%A2%BA%E3%81%A7%E3%81%99%2C%2C%2C%E3%81%94%E4%B8%8D%E4%BE%BF%E3%82%92%E3%81%8A%E3%81%8B%E3%81%91%E3%81%97%E3%81%A6%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2039788%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AEMIOS0%20MPC5748G%E3%81%AEinputcatch%20IPWM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2039788%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%E7%A7%81%E3%81%8C%E6%AC%B2%E3%81%97%E3%81%84%E3%81%AE%E3%81%AF%E3%80%81%E4%BF%A1%E5%8F%B7%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%8B%E3%82%89BSW%E3%81%A7Freq%E3%81%A8Duty%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%A6%81%E4%BB%B6%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E8%BF%B0%E3%81%B9%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%0A%3CP%3E%E3%81%84%E3%81%84%E3%81%AD%3A4%E3%81%A4%E3%81%AEPWM%E4%BF%A1%E5%8F%B7%E3%82%92eMIOS%E3%81%A7%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%97%E3%80%812%E3%81%A4%E3%81%AEPWM%E5%87%BA%E5%8A%9B%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%9F%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%90%84%E6%9C%9F%E9%96%93%E3%81%A7%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%2FDMA%E3%81%AA%E3%81%A9%E3%82%92%E4%B8%8A%E6%98%87%E3%81%95%E3%81%9B%E3%81%9F%E3%81%84...%3C%2FP%3E%0A%3CP%3E%E3%81%A0%E3%81%8B%E3%82%89%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%82%E3%81%AE%E3%82%92%E3%81%AF%E3%81%A3%E3%81%8D%E3%82%8A%E3%81%A8%E8%A6%8B%E3%81%BE%E3%81%99%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%82%92%E5%B0%8E%E3%81%8F%2F%E3%83%92%E3%83%B3%E3%83%88%E3%82%92%E4%B8%8E%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2039724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AEMIOS0%20MPC5748G%E3%81%AEinputcatch%20IPWM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2039724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%BE%E3%81%9F%E3%80%81%E5%90%84IRQhandler%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%A7%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%82%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%81%A0%E3%81%8B%E3%82%89%E3%80%81%E7%A7%81%E3%81%AF%E3%81%AA%E3%81%9CIRQhandler%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%A7%E3%81%AA%E3%81%84%E3%81%AE%E3%81%8B%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%AE%E3%81%AF%E3%80%81%E5%90%84%E3%83%9D%E3%83%BC%E3%83%88%E3%83%94%E3%83%B3%E3%81%8CPWM%E5%85%A5%E5%8A%9B%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%81%A3%E3%81%9F%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%AA%E3%81%9CeMIOS_UC%E3%81%AE%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82UC%5Bchannel%5D%20%E3%81%A7%E3%81%99%E3%80%82SR%20%E3%81%8C%201%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2039588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AEMIOS0%20MPC5748G%E3%81%AEinputcatch%20IPWM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2039588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%BE%E3%81%9A%E3%80%81%E3%81%94%E6%94%AF%E6%8F%B4%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99!!%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81IPWM%E5%85%A5%E5%8A%9B%E3%82%AD%E3%83%A3%E3%83%83%E3%83%81%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81EMIOS%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AB%E4%BD%9C%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AAOPWM%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3EeMIOS_UC_0.UC%5B0%5D%20%E3%81%A7%E3%81%99%E3%80%82CB%E3%83%A2%E3%83%BC%E3%83%89%20%3D%200x60%3BOWPMB%E3%83%A2%E3%83%BC%E3%83%89%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%8C%E6%AC%B2%E3%81%97%E3%81%84%E3%81%AE%E3%81%AF%E3%80%81%E4%BF%A1%E5%8F%B7%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%8B%E3%82%89BSW%E3%81%A7Freq%E3%81%A8Duty%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2039120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AEMIOS0%20MPC5748G%E3%81%AEinputcatch%20IPWM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2039120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%E3%82%B7%E3%83%95%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%20PWM%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BE%8B%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F2%E3%81%A4%E3%81%AE%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AFMPC5748G%E3%81%A7%E5%86%8D%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMPC5xxx-Knowledge-Base%2FExample-MPC5746C-eMIOS-Shifted-PWM-GHS716%2Fta-p%2F1159152%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMPC5xxx-Knowledge-Base%2FExample-MPC5746C-eMIOS-Shifted-PWM-GHS716%2Fta-p%2F1159152%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E
