files not found to flash while using codewarrior 10.6 version
arthivenkatasub
With the codewarrior v10.6 ,while flashing code into the MPC5643L controller using debugger, a message is shown as image files not found. Whereas, the same code is flashed to the same controller using codewarrior version 2.10. I dont know where i am missing.
Arthi V
Original Attachment has been moved to: DPM_mode.zip
martin_kovar
it looks like you have incorrectly set paths in the project. Could you please share your projects to check it?
Martin
arthivenkatasub
Hi Sir,
I have attached the example project files which i was trying to flash. Please check it. I have updated it in the question. I have also checked the path location.
Arthi
