eptu_cw code
eptu_cw code
xiaojin
I download etpu code form
http://www.nxp.com/webapp/etpu_cw/
I want to use GPIO/IC/OC/PWM functions, but only the GPIO function are ok, the IC/OC/PWM functions doesn't work.
I find that the IC/OC/PWM api interface is not up to date, can you provide me the etpu api which is suitable for etpu_cw funcitons?
MilanBrejl
Correct API for OC, IC, PWM (PowerPC version) is now up on the Function Selector. Please create the function set and download again.
-Milan
