eTPU code samples
eTPU code samples
1,929 次查看
snehakalkhair
Please help me with a few eTPU code samples.
eTPU to raise an interrupt.
eTPU , eMIOS interaction.eg. generate PWM with eTPU and measure the generated PWM using eMIOS.
标记 (2)
1,683 次查看
davidtosenovjan
To eTPU part:
First I would recommend to read general response I have recently answered on our community:
https://community.freescale.com/thread/371589
Here you can example procedure how to use eTPU PWM function, step by step:
http://cache.freescale.com/files/soft_dev_tools/doc/app_note/AN4687.pdf
To eMIOS part:
eMIOS functionality should be understandable from reference manual.
I am attaching example showing you half of the task that is IPWM function (for duty cycle measurement) - note this is not my code, no warranty.
For period measurement you would then use IPM function.
Also I would recommend taking a look on EB651, chapters 2.1 and 2.2:
http://cache.freescale.com/files/32bit/doc/app_note/EB651.pdf
