dual core ${ProjDirPath} command issue
1,898 次查看
supra0309
Hi:
I'm using 5746R to accomplish dual core function. Referenced from example s32r274_shmem_S32DS_Power_v1.2(https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/Example-S32R274-multi-core-shared-memo... I found there's a linker setting in s32r274_shmem_Z7_1. But I can't figure out the detail shows in "${ProjDirPath}/../s32r274_shmem_Z7_0/Debug/src/shared_mem.o" which is hidden with "..". Please tell me the detailed description. Thanks.
BR,
Xantia
1,877 次查看
petervlna
Correct me if I am wrong, but are you asking me what is the full path of "shared_mem.o" located at your PC machine?
Peter
1,873 次查看
supra0309
Hi:
I'm not sure what it means in this item. I tried to point it to workspace folder on my PC, but system showed some header files "No such file or directory" in core z4_1 project which are assigned in core z4_0 project.
How should I fix it, thanks
BR,
Xantia
1,866 次查看
petervlna
Either copy requested header files to the path you have set in config
or edit path properties to point in the location where you have that file.
Peter
