device interfacing with mpc5606b
akhilmalik
hi
can you please tell which zigbee(xbee) and global position system sensor is compatible with mpc5606b
akhilmalik
hi
gps is also connected with serial port or can be connected with pins.
alexvinchev
Contributor V
I'm not sure what you are asking... In general each serial port should have at least Rx and Tx pins. You need GND as well.
alexvinchev
Contributor V
There are many GPS & ZigBee devices, which support serial port. Any of them is compatible with your MCU. You might need level shifter for some of them, but anyway, they are compatible.
