device interfacing with mpc5606b
2,040件の閲覧回数
akhilmalik
hi
can you please tell which zigbee(xbee) and global position system sensor is compatible with mpc5606b
3 返答(返信)
1,883件の閲覧回数
akhilmalik
hi
gps is also connected with serial port or can be connected with pins.
1,884件の閲覧回数
alexvinchev
Contributor V
I'm not sure what you are asking... In general each serial port should have at least Rx and Tx pins. You need GND as well.
1,884件の閲覧回数
alexvinchev
Contributor V
There are many GPS & ZigBee devices, which support serial port. Any of them is compatible with your MCU. You might need level shifter for some of them, but anyway, they are compatible.
