debug core_2 in MPC5748G
dineshram
Hi sir,
Iam workimng on MPC5748G write now i can able to debug the code in core_1 but core_2 iam unable to begug is there any setting .
petervlna
Sure, first you have to have active core2 in your device. Check the Mode entry register CS (core status)
And if the core is active, then switch in your debug tool to the core2. For example in Lauterbach debugger enter: sys.config core 2 1
Peter
