breakpoint installation failed: remote communication error
ソリューションへジャンプ
3,018件の閲覧回数
lixu
    When I use  Design Studio for Power Architecture Version 2.1  for project compilation, it shows "Breakpoints installation failed: remote communication".
   I'm just beginning to learn this and this problem has been bothering me for a long time.
   Please answer me, thanks.
3,008件の閲覧回数
Questioner
Same Error had occured for me also, I think you have enabled skip all breakpoints options.
RUN->skip breakpoints.
4 返答(返信)
3,009件の閲覧回数
Questioner
2,989件の閲覧回数
lixu
Thank you. This is exactly the solution I wanted. It's very useful!
3,010件の閲覧回数
petervlna
Could you provide more details?
In which phase you are setting breakpoints? Isn't is when the debug session is running?
best regards,
Peter
2,986件の閲覧回数
lixu
The problem has been solved. Thank you for your attention!
