Where do I find the TPU function library for MPC555?
4,160 次查看
s_martinkus
Hi guys,
I would like to use the microcontroller MPC555 to detect the speed of a crank type 60-2 (two teeth are missing).
In document TPUPN00.pdf on site 13: Appendix B - TPU function library I have found a hint, that new functions of the TPU might be available on Freescale bulletin board.
Where do I find this bulletin board?
May I ask you, to help me?
Does already exist such source code for a speed detection of a crank type 60-2 for MPC555?
Thank you for your support in advance.
bye.
3,937 次查看
s_martinkus
Hello Mrs Monica Arvizu,
yes this issue has been solved out.
The MPC555 is an old microcrontroller and it's not easy to find all stuff for it any more.
Take a look to http://www.eslave.net/tpu/source/source.shtml and you may find all functions you need.
After you've collected the functions you should assemble them into a function mask.
For more info study the document TPUPN00.
Bye.
3,937 次查看
Monica
Senior Contributor III
Hello s.martinkus!
I heard this issue has been solved out.
Would you mind sharing the workarounds? That would be great for Community fellas :smileyhappy:
Monica
3,938 次查看
s_martinkus
Bye.
3,937 次查看
Monica
Much appreciated, s.martinkus!
Thanks to MilanBrejl too :smileywink:
Have a great day!
Monica
