VDD_HV_ADC0 internal voltage monitoring
housseinbah10
Hi, I would like to know how to read the internal voltage VDD_HV_ADC0 of channel 18 of ADC0.
I have already make it for VDD_HV_ADC1 by enabling channel 50 of register ADCx_NCMR1 and it works correclty.
Can you please help me out how did you configure and enabling channel 18 of ADC0 ?
Houssein
PetrS
CH18 is valid bit too, check below table
The bit can be set and conversion takes place.
BR, Petr
PetrS
set CH18 bit in ADC0_NCMR0 and start conversion on ADC0.
BR, Petr
housseinbah10
Hi PetrS
The normal conversion mask register NCMR0 does not contain field or bit enable for setting channel 18.
This was my principal issue
thanks
PetrS
BR, Petr
housseinbah10
Thank for your clarification,
