[SPC58NG] Program DCF record fail
Tran_Tam
Hi guys,
I'm using Lauterbach to program DCF record to UTEST block. After I run my cmm script, there is no error but the DCF record is not program to the UTEST.
The DCF record start address is 0x00400370, I have dumped memory and see that there is no DCF record at this address.
Because the Flash memory programming resolution is 128 bits, thus I write 2 DCF records  within 1 Flash programming operation, like this
"Data.set 0x00400370 %QUAD 0x0000003100400040 0x0000003100400040;"
You can check my attached cmm script.
I'm don't know what is problem, please help me to check it.
davidtosenovjan
SPC58NG is product of STMicro, please contact their support:
https://www.st.com/content/st_com/en/support/support-home.html
