S-record problem for bootloader on MPC5777C
berat24
Hello everyone,
I am trying to send S-record file attached following link to MPC5777C for rappid bootloader. (https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/RAppID-Bootloader-custom-rbf-files/ta-...)
However, s32_ide and pe_micro device cannot send s-record file due to some reasons. I attached compiler messages to below as a notapad. Could you give me feedback about that? What could be reason?
lukaszadrapa
Hi Berat,
do you follow this HOWTO document?
https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/HOWTO-download-separate-elf-srec-hex-f...
Of if you have Pemicro Multilink, you can download this free version programming utility limited to 64K which, I believe, should be sufficient for the RBF:
https://www.pemicro.com/downloads/download_file.cfm?download_id=194
Lukas
lukaszadrapa
Hi Berat,
Lukas
