Routine recognization question
1,422 次查看
TingTing
Hi Developer,
How Can I know which routine is running now?
For example, I have 3 routine on PFlash, which named A, B, C. Each routine can work at one time. When A confirm B exist,A call B. When B confirm C exist, B call C. How can I konw which routine is running now without debugger or NVM.
Dose there any way to do this?
PS: My board is MPC5746R.
Waiting for your response.
Many thanks.
BR, Shi Ting Ting.
1,409 次查看
lukaszadrapa
this should be handled on software level. You can use some status variable which should be updated accordingly at beginning and at end of each function/task.
Lukas
1,409 次查看
lukaszadrapa
Lukas
