Reference Design using MPC5676 Microcontroller
mathiyazhaganpa
I am planning to use MPC5676 for my new motor controller and an automotive control application, My application is to control two PMSM motors simultaneously for an position control application. My system will be using three CAN interface for interfacing with other systems. The system will have extensive built in test facility. My frame time will be 2ms. For that i have choosen MPC5676. I would like to get your advice on the same. Can i get the Reference design for the same microcontroller. Orcard Part for the same.
Mathiyazhagan
lukaszadrapa
I forgot to mention that a lot of reference designs for motor control can be found here:
Automotive Motor Control Development Solutions|NXP
Lukas
lukaszadrapa
I already answered here:
Require of MPC5676r development Schematic
Attached you will find symbols and footprints for Cadence Allegro.
Lukas
