Recent header file for MPC5748G
3,557件の閲覧回数
alexvinchev
Contributor V
recent header files, found in AN4830, Freescale Recipes for MPC574xG - Application notes (REV 1) are 2.1.12a for mask 0N65H and 4.0.01 for mask 1N81M.
I know that there is only one newer revision for 0N65H (2.1.13).
Is there any newer revision for 1N81M? I'm asking, because supplied one is false regarding CAN1-7 definition (and maybe somewhere else), when checking versus MPC5748G - Reference Manual (REV 4) document. At least FDEN bit is not present in MCR, IMASK3 and IFLAG3 registers are missing.
タグ(2)
7 返答(返信)
2,840件の閲覧回数
petervlna
Attached is latest header file ver_5.00.
EDIT: " Seems that revision 5.00 have some issues also on apps team side."
Peter
2,840件の閲覧回数
alexvinchev
Contributor V
Hi Peter, sorry to bother you again, but did someone tried to build with this file?
There is multiple structure (eMIOS_tag) definition at rows 14419 and 14522...
2,840件の閲覧回数
petervlna
You are right.
I wonder why author didn't tested it and put it on our official internal site.
Peter
2,840件の閲覧回数
petervlna
I was speaking with apps team and they have recommended to use 4.xx version of header file.
As the 5.00 have some issue at this time.
I am not able to fix the actual header file as this must be done by application team to maintain consistency in revisions.
Peter
2,840件の閲覧回数
alexvinchev
Contributor V
Thanks!
This header, even with some problems, helped me in CAN FD definitions.
Greetings,
Aleksandar
2,840件の閲覧回数
petervlna
You are welcome.
Peter
2,840件の閲覧回数
alexvinchev
Contributor V
Thank you very much Peter!
