Rebuilding only part of the model
Ahmed_Abd_El-Hafez
Hello NXP team,
When I modify some points in the Model and build it to download on the target board, is it necessary to rebuild  the whole model or there is a capability of rebuilding the modified blocks or subsystem only and include it in the last generated code to reduce the code generation time? if there is, how?
Thank you in advance
Best Regards
Ahmed
davidtosenovjan
Could you specify used device a which kind of model you have on your mind? Please clarify context of this question. Thanks
Ahmed_Abd_El-Hafez
I mean Model Based Design on Simulink [for using FOC to control PMSM for example]. like the models in the modules of this workshop https://community.nxp.com/t5/Model-Based-Design-Toolbox-MBDT/3-Phase-PMSM-Control-Workshop-with-NXP-...
I am using MPC5744P MCU.
davidtosenovjan
Please create community thread within following community space and competent person will assist you:
https://community.nxp.com/t5/Model-Based-Design-Toolbox-MBDT/ct-p/mbdt
Thanks for understanding
